Message |
[ http://specialtyz.com/blog/?page_id=178 ] You sure its turbo smoke out the exhaust and not your clutch disc burning up? The reason I mention is I thought my clutch pedal properly adjusted for SZ Street Max clutch, and it started slipping on full pull's. The short is that I had adjusted the top of the pedal travel as prescribed, but there wasn't any play from the slave cylinder to the clutch fork (you should be able to pull it towards you). When going full throttle the exhaust can heat up the clutch line, causing the fluid to expand and slightly disengage the clutch. Ended up adjusting the rod coming from the clutch master to, and now I'm good to go!
